I replaced the lamp and now the tv wont turn on
The most common cause of this is the access doors not being seated correctly. Please try and reopen and close all of the access doors. There are interlocks that need to be activated in order for the set to turn on.
Also, the indicator lights on the front should be blinking a code to indicate if the problem is the door, lamp or fan. Please post any lights that are present if the reseating does not resolve the problem.
Thanks,
Dan
power is blinking red
That was the solution! thank you!!
i have the same Problem
I just changed the lamp and the power standby light is flashing 3 times red .
Any help would be much appreciated..if this is an access door not seated properly, could you tell me what an access door is?
I tried it still red blinking light anything else i can try
