I HOKED UP A VIZIO SOUND BAR TO THE AUDIO OUT LIKE STATED BUT NO SOUND FROM BAR. POWER IS OK COULD MY TV JACKS BE BAD? WHAT DO I DO?? THANK YOU KATHY
SOURCE: Protron PLTV 32 - audio output jacks not working correctly
Hi reb21, From the Audio menu check and make sure your audio output is not set to Mono, anyother setting should produce a an output signal on both wires. Let me know if this helps and please rate this solution. lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
SOURCE: Protron 26 inch lcd.....turn on, picture flashes
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc. Look for 5vdc, 12vdc, and 24dvc.
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Protron+PLTV-26+
Please post back what you find.
