Watches Logo
mimi Posted on Apr 14, 2013
What type of battery does a zodiac model z04525 have
2answers
How do i replace battery in zodiac zmx 03 watch?
http://www.fixya.com/search/p1791965-zodiac_zodiac_zmx_03_watch_zo8507/battery_replace
I have a zodiac 1882 what type of battery does it need?
It's a 395 (SR 927 SW), however you're going to need a case wrench and a 4-pin vise to get the back off so you're looking at a minimum of $40 for the battery and the tools and that's if you know where to look. The other problem is the rubber gasket which may need to be replaced as well. Unless you happen to have a supply of them handy for that exact size case, your watch will no longer be water resistant to the manufacturers specifications. You could probably wash your hands with it but I wouldn't recommend anything more intense. The problem that you have is that you won't know if you need a new gasket until you get the case open and as noted, that's cost you a minimum of $40 to find out and you get the pleasure of having a set of tools that you'll probably never use again. Or, you could save yourself the money, headache and aggravation and of course the high probability of you damaging it because you lack the experience to change the battery on a screw-back, water resistant timepiece and just take it to a local jeweler, pay $10 - $15 to professionals who know what they are doing and will include the replacing of the gasket at no extra charge.
A universal Screw-Back (what your watch has) Watch and a Case Wrench captainhawk1_18.jpg
1helpful
My Sea Dragon watch has stopped. I've tried winding the stem in the closed position until I'm blue in the face, but it won't re-start. Any tips?
All of the models I looked at are quartz types (which are battery driven).
This would account for the failure to wind it up.
You can have a new battery fitted at your local watch shop.
1helpful
Replace mineral crystal in Zodiac Sea Dragon ZO-2201
Its better you bring your watch to a service center ,Because equipped of all the tools.
Hope it may helps;
3helpful
How do I close the stem on a zodiac watch?
Your watch do not have screw down crown feature. You can only pull out or push in that crown.
Check instructions for yourself from the official Zodiac document here:
https://www.zodiacwatches.com/images/pdf/zodiac_watchinstructions.pdf
Rate me, please.
Top Zodiac Watches Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Zodiac Watch Expert? Answer questions, earn points and help others
