vx110 , are all cylinders working ?? could be plugs, injecters, or worse the valves aresticking open ! pressure drop test by dealer !! compression test also ! clean fuel ??
The warning light that you see is for tyres maybe one of your tyres is flat you can check that all the tyres for pressure then you can rest the warning light.
What does the alarm (display) say is the problem? Normaly you will get a specific error like Water TMP or Exhst. I am guessing exhaust and with that it is most likely the catalytic converver has become loose and lodged further down the exhaust.
orange circle with dashed lines each side indicates worn brake pads, circle with cross through indicates bulb failure. third orange light indicates brake light bulb faiure
