Re: Riccar vacuum Moon 1 just won't turn on, any ideas?
Check cord, esp at entry point. Otherwise it may be switch, motor windings burnt out, broken wire, carbon brushes worn. Some appliances also have a thermal fuse, which is a silver tube shape.
Question edited for clarity and spelling of maker.
Question moved from TX Watches category.
Try the thermal reset again. When you are using the vacuum and then turn it off, the motor is hot and there is no cooling airflow. If the vacuum is close to cutting out through overheating that lack of air will trip it. If you have digital multimeter, you can check the thermal switch for continuity.
Riccarhttp://media.riccar.com > 8000_Owners_Manual
How to Replace the Agitator Belt. (Models 8750 8850 & 8800 only). Unplug the units power cord. Turn the unit over and remove the bottom plate as described in ...
13 pages
If this problem happened after you replaced the filters, check that the filters have been installed correctly because some filters have sensor magnets installed on them and unless they are in their correct position, the machine wont power on.
try a different power cord, otherwise it is a thermal issue. if it is a thermal issue, call or e-mail tech support, and send it in. otherwise you could get it repaired @ any local vacuum cleaner dealer
