Canon PIXMA MX330 Office All In One All-In-One InkJet Printer Logo
Fred G. Webster Posted on Apr 14, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I print double sided documents automatically?
Anonymous
Level 3:
  • Canon Master 32,281 Answers
  • Posted on Apr 14, 2013
Anonymous
Canon Master
Level 3:
Answers
32281
Questions
Helped
7913227
Points
102259
You cannot print double sided docs automatically with this model printer because it does not have a duplex unit.
Check out the specs from this WEB site.
http://reviews.cnet.com/multifunction-devices/canon-pixma-mx330/4507-3181_7-33529115.html
1helpful
3answers
My Epson L120 won't print on both sides whenever I print on my Mac OS: Monterey?
Unfortunately, 2-sided printing is only available for the Epson L20 when used with the Windows OS. See page 22 of the user guide available here: https://www.epson.com.ph/Ink-Tank-Printers/L-Series/Epson-L120/s/SPT_C11CD76401?review-filter=Mac+OS+X+10.11.x#manuals . The current link to the manual is http://support2.epson.net/manuals/english/ij/l120/pdf/npd4965-00.pdf . You might be able to use the Duplex feature if you install BootCamp and an licensed version of Windows (XP up to WIndows 10). Neither BootCamp or licensed copies of Windows are free.
I wish that I had better news for you.
Double sided copies
Your printer has Duplex printing Capabilities. However when you are ready to send the print job, open the Printer Properties and select Double Sided.
To copy a Double sided document, insert it in the ADF (Automatic Document Feeder) and open the copy settings on the machine and select Double sided.
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Double sided printing
How to duplex print with 895cxi
This model printer does not have a duplex unit and cannot print double sided documents automatically.
1helpful
HP D7260 will not print two sided
This model printer does not have a duplex unit and therefore cannot print double sided printing automatically.
How to print two sides
1helpful
2answers
How to set a MG5220 printer to do 2-sided copies?
The Canon MG5220 has a built-in auto duplexer and can print 2-sided documents. On a Mac, click print, and in the print dialog box select Duplex Printing & Margins (drop down options below Printer and Presets). Check the Duplex Priting box, and selected the Stapling side. Then click Print. That's it!!
3helpful
2answers
Do pixma Mp610 support duplex printing
The MP610 does support duplex printing.
Duplex Printing
The duplex printing function allows you to print data on both sides of a sheet of paper.
The procedure for performing duplex printing is as follows:
Performing automatic duplex printing
You can perform the duplex printing without having to turn over the paper.
1. Open the printer driver setup window, check the Duplex Printing check box, and confirm that Automatic is checked.
2. Select Normal-size Printing (or Fit-to-Page Printing, Scaled Printing or Page Layout Printing) from the Page Layout list.
3. When printing a document that has small margins, click Print Area Setup... and set the print area.
When you perform duplex printing, the print area of the document becomes slightly narrower than usual and the document may not fit on one page.
sub.gifTo print without reducing the page:
Select Use normal-size printing.
sub.gifTo reduce the page slightly during printing:
Select Use reduced printing.
4. Specify Staple Side.
The printer analyzes the Orientation and Page Layout settings, and automatically selects the best staple position. Check the Staple Side setting. If you want to change the setting, select another value from the list.
5. If necessary, click Specify Margin... and set the Margin width.
6. Click OK.
Duplex printing will be started.
Performing duplex printing manually
You can perform the duplex printing manually.
1. Check the Duplex Printing check box and uncheck the Automatic check box on the Page Setup tab.
3. Specify Staple Side.
4. If necessary, click Specify Margin... and set the Margin width.
5. Click OK.
sub.gifIf a media type other than Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed on one side of a sheet of paper. When printing is complete, reload paper according to the displayed message and then click OK. The document will be printed on the opposite side.
sub.gifIf Photo Paper Plus Double Sided is selected for Media Type on the Main tab:
When you execute print, the document will be printed front and back alternately for one sheet at a time. Load the paper according to the displayed messages.
caution.gif Note sub.gifDuplex Printing is unavailable when:
- A media type other than Plain Paper, Photo Paper Plus Double Sided or Hagaki is selected from the Media Type list.
- Poster Printing is selected from the Page Layout list.
sub.gifWhen Booklet Printing is selected from the Page Layout list, Duplex Printing and Staple Side appear grayed out and are unavailable.
sub.gifAfter printing the front page, there is an ink drying wait time before starting to print the back page (Operation stops temporarily). Do not touch the paper during the time. You can change the Ink Drying Wait Time at Custom Settings on the Maintenance tab of the printer driver.
sub.gifWhen you perform the automatic duplex printing for Hagaki, print an address first and then print your message.
refer.gif Tip sub.gifIf you select Photo Paper Plus Double Sided for Media Type on the Main tab, the Duplex Printing check box on the Page Setup tab is not checked automatically. To perform duplex printing, check the Duplex Printing check box.
sub.gifIf the Media Type dialog box appears when performing borderless printing during duplex printing, select Plain Paper or Photo Paper Plus Double Sided.
sub.gifWhen performing the automatic duplex printing, do not use any plain paper smaller than A5. Also, do not select any type of paper other than Plain Paper, Photo Paper Plus Double Sided or Hagaki at Media Type.
sub.gifPhoto Paper Plus Double Sided is highly recommended for printing photographs on both sides of a page.
sub.gifIf the back side of the paper becomes smudged during duplex printing, perform Bottom Plate Cleaning in the Maintenance tab.
old marine
old marine
ZJ Limited
ZJ Limited
