Hi everyone.I have a Xantrex freedom 20 inverter charger.My problem is that the inverter works but it won't charge my batteries.The batteries read 12.5 volts so low batteries must not be the prob.Any help would be great!!! Kelly
The problem is the batteries. 1) Check the age of them to assure they are not near warranty limit. If so change them. 2) They must be topped off. I recommend using distilled water within every 30-60 days. Summary: After doing item 2 above charge them with an external charger; while connected to inverter is ok. Does this help?
Check if the inverter has a fuse for the charger, if it does test it if it is still ok if not change it
My charger will not work either. Inverter works fine. Charger will not start when shore power is hooked up. I tried to disconnect it to reboot it but same problem exists. HELP!
