Galaxy young 5360
Get to recovery/download mode by pressing volume up button , home button & power button, press these 3 buttons together &hold for 5-10 seconds same time then you will be able to see recovery mode there choose the option wipe data/factory reset,remember it will erase your data even though it will solve your problem.
Please rate my answer.
Use a computer to log on, then log on with your phone.
SOURCE: i have a samsung galaxy
The way around this is to factory reset the phone.
1. switch off. Hold volume UP and power button and home button
simultaneously. release home button (and press again) while still
holding volume up and power button. A boot up screen will pop up. Use
volume keys to select (reset and restore) press home button to select.
2.Once reset and the phone starts up again it will still show locked.
Get another phone to call your phone. as soon as you swipe answer press
back key (arrow key) (you gotta be quick) and the main home screen will
come up . press the left menu button and select settings and turn
off pattern code then go to menu and factory reset the phone again.
Hope this helps.
SOURCE: samsung galaxy android unlock..cannot unlock my
Hi, I have a couple of idea for you to try.
1) Log in to your google account on your pc, the same account you registered for your phone
2) After logging in look at the top right corner of your inbox/email page, it would say your google username. Like say if you name is John, and you have a google id thats registered to your galaxy s as , [email protected]. Now this google id on the top right corner of the page would be displayed as [email protected]
3) Type in the google id, thats visible on the right hand top corner of your page (like [email protected]) into your galaxy s handset locked page, and type in the password.
TADA AND YOUR ON TO THE NEW SCREEN TELLING YOU TO PUT IN ANOTHER PATTERN.
or theres this one:
Take out the battery, the sim card, and the SD card leave the phone for 2 to 3 hours like that.. Put everything back in and boot up the phone.. This should work.
You could try this instead of waiting 3 hours, just remove battery and press power on switch for 20 seconds but this may not work.
or if you've tried everything, the only other way would be to take it to a Samsung mobile phone shop.
or do a factory reset:
THIS WILL ERASE ALL YOUR DATA THOUGH
Go into recovery mode - vol up & home & power. Once in the menu, select factory reset.It may take you a couple of attempts to get to the recovery mode but it does work, just keep trying.
Regards
Mike
SOURCE: i tried unlockin my galaxy
Try clicking "forgot my password" on Google from a computer. It should assist you in recovering your google password.
SOURCE: how to reset samsung galaxy 551
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
