SOURCE: dell axim x30
HI You have two ways: 1) Install the ActiveSync (Version 4.2 is recommended) PC Software with your PC first Next, you connect your Axim to your PC. Then you install the software or game into your PC. it will also install into your Axim automatically thru Sync process. 2) Or install the software or games into your External SD Memory card thru USB SD Card reader. Then put your sd memory card into your Axim and run the software or game. The 2GB or 4GB SD Card is reccommended since the game or software sometime is huge. I hope it is help. Regards, pingping
SOURCE: dell axim x5 1180 truemobile wireless issues
Only WEP is supported------- also download the rom patch for this card off of the Dell site.
SOURCE: Connect to the Internet
ok, this is a little technical, dell decided to make a complicated WiFi system for this, but once ou get the hang opf it you will be able to connect in no tim.
1. push the WiFi button located on the lower right side , it kind of is flush with the body
2. wait about 20 seconds, if the WiFi meter in the lower right corner of the screen does not change the you will have to go deeper into the system.
3.hopefuly you have noticed the blue light flashing by now, if it has an erratic flash , it is searching for a signal
4.no wifi yet? ok use the stylus to tap the wifi meter bar on the screen, this will show a menu consisting of a (WiFi radio on/off option, edit profiles option, WLan status option, site survey option, advanced, and versions.
5.tap the WLan staus option, this will bring you to the menu, this menu can also be accessed by going to settings. anyway look at the bars for link quality and strenghth, if they have a little bit of blue or none at allgo to site survey at the bottom of the screen
6.this menu shows al the available wifi networks in your area, ifnone show up, and you know you are near one tap the profiles setting, this will show all the nearby sites you can tap and hold any of these sites and manually connect to the internet that way.
7. I warn you , the dell x30 is a little wonky a great PDA and usually works great for the internet but sometimes it jsut plain refuses to actually connect to a site, even though it has a connection. I haqve found the best way to cure this is to do a soft reset, and reconnect.
If this still doesnt work for you, feel free to repost this question or email me, i might be able to help with some more details
SOURCE: Dell Axim X3 HC02U Pocket PC PDA
I HAVE PROBLEM, MY PDA IN JAPANES LANGUAGE. HOW TO INSTALL WITH ENGLISH LANGUAGE?
SOURCE: set password on my dell axim X51v pocket pc and forgot it
Once you forget the Password, your only option is to perform a Hard Reset on the device and reset back to Factory defaults. You data will be lost, as this is in place to protect you in case the device has been lost or stolen. If you have backups, or sync the device with Outlook, you can run a restore or re-sync the device to populate the data back into your device.
Hard Reset -
NOTICE: When you do a hard reset, you lose all the data stored in your device
Flash memory, and any programs that you installed on your device.
Do a hard reset if:
NOTICE: It is strongly recommended that you back up your data before you do a hard reset.
To do a hard reset:
