Black screen is displaying operating system not found. Is there anyway to get the computer working again without loosing any data.
Check hard disk connecting jack,,clean pins & reinstall connector
Remove the HDD and test. It sounds like your HDD is gone. Can you get to the Boot Menu? Do a System Restore? Is the HDD LED blinking at boot? Will it boot to safe mode? Your data may be in jeopardy.
the only thing i can do is press f12 and then it says media test failure
Remove and reseat the primary HDD, if that dosen't help, Remove the HDD and test replace if necessary. Does your DVD/CD rom drive work? If you insert a repair disk, does it load? Can you get to BIOS setup at POST, by tapping the setup F key? Take a look at thishttp://www.kb.sony.com/selfservice/viewC...
