Canon Printer Not Responding is a common error that you might get. This error can be displayed because of several reasons like Outdated drivers, weaken network connections, USB problems, and much more. For resolving this error, you have to follow the troubleshooting steps mentioned below. These are the basic procedures that will help you to resolve the error successfully.
Methods to Troubleshoot Canon Printer Not Responding:
Run the Printer Troubleshooter to Fix Canon Printer No Response Error:
The windows have a built-in printer troubleshooter that can fix your error. This tool will help you out to fix the issue of the printer not responding:
Press the "window logo key" and type "troubleshoot". Then select Troubleshoot or Troubleshooting.
In troubleshooter, click Printer and then "Run the troubleshooter" (using windows 10)
Click "Use a Printer" (using windows 7)
Follow the following instructions to complete the troubleshooting. If this works for you then you don't have to go on further methods.
Restart the Printer Spooler Service:
The printer spooler service on your computer manages your communication between your printer and computer and print jobs. If this service is not working properly on the computer then your canon printer will stop responding. You have to reset this service to fix your printer issue.
Press the "window logo key" and R simultaneously on your keyboard to request the Run.
In the Run type "service. MSC" and press Enter.
Click "Print Spooler and then click Restart.
Check that your printer is printing the document.
For More Follow this:-
