Panasonic Workio DP-150PA Copier Logo
Posted on Mar 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
IP address problem
I use Panasonic workio 8020 Photocopier for Network printing
But I have a problem for IP address
Ken Shepherd
Level 2:
Scholar:
  • Expert 95 Answers
  • Posted on May 21, 2009
Ken Shepherd
Expert
Level 2:
Scholar:
Answers
95
Questions
0
Helped
41823
Points
174
What problem? Need more info! On the Panasonic brand, you input the IP address through the "function" mode- "general" settings... go to last menu item "key operator" the code should be 3 or 4 zeros. Then go to the IP address item and enetr in the IP adress. Now you MUST TURN THE MACHINE OFF AND BACK ON TO LOCK IN THE IP ADDRESS! Go back into general setting and "print general settings" to see if it's still the same address.
IS panasonic WORKiO DP - 1520P NETWORK OR USB PRINTER
Network printer. Set IP address in function/general settings
I have Panasonic network printer workio 8020, Fault code J93 is showing on display but there is no paper misfed in adf.
There is a sensor that is either knocked out of position or broken. It is not that difficult to take apart if you are a bit handy. First remove the covers and then remove the top cover.
Pleas; I want panasonic workio dp8020 drivers for xp, to use it as a prinert to print A3 , many thanks for you
Drivers for Panasonic WORKiO DP-8020 can be download from the Panasonic official support site. Drivers and all instructions are available here.
Let me know if any further clarification/ assistance is required.
Good Luck!
Dont forget to appreciate the solution if I could have been of any help!
CreativeTECH
We have a Panasonic PD-3520 setup with a static IP Address and attached to our companies print server. I can ping the IP address of the device, but when I try to print it has a rather long delay and then...
check the subnet mask address and also if it is going through a router this will have to be entered as server id..or gateway address..hope this helps..A
9helpful
How do i change IP address for network printing
yep!
you mean the ip address of the copier?
it is under general settings key operator mode
here's how to do it:
1. set the machine to copy mode (ready to copy displayed on LCD)
2. press FUNCTION
3. press 1
4. press SET
5. press 9
6. press 000 (as a default key operator password)
7. press 1 and 9 ( 19 )
8. the tcp/ip mode will display
you may press clear to erase the current ip address;
just press the number that corresponds to your desired ip address and asterisk (*) corresponds to dot ( . ); after you input the new ip address dont forget to press SET to save the settings
press STOP TO EXIT
that's it :)
1helpful
Have a Panasonic Workio 8020 machine, is showing
Change copier to Fax mode - Function button no. 7 (set mode) and then No.1 (user parameters)
Need IP address of Workio dp-2330
"share" it on your server, then on each PC go to "add printer", select "network Printer", browse your network, and select the printer.
How to setup the IP address for Workio DP2500?
it uses dhcp by default. connect to network with dhcp.
1. print test or configuration page from menu. then connect through internet explorer.
2. install software from original cd and configure through it
DP-190 Network Printer
I succeeded in printing via network to the Panasonic Workio DP-190.  Here is a brief summary of what needed to be done...
* HP laptop w/ Windows XP SP2 installed * requires LPR support via "Print Services for Unix" to be installed from Windows Components (http://technet.microsoft.com/en-us/library/bb457002.aspx) * Installed using GDI printer driver (http://panasonic.co.jp/pcc/products/en/mfp/download/dp-190/list.html)
During the GDI installation I choose a 'Network printer' and the printer was already setup for proper IP addressing, etc...
I created a new printer port of type LPR, doing so required me to input the printer's IP address and a queue name -- the queue name was left blank.
Hope this helps, John
Top Panasonic Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
