For the 6 cylinder 4.0 Liter EFI (electronic fuel injection) SOHC (single overhead cam) engine
(8th digit of VIN = "E"), and
the 8 cylinder 5.0Liter EFI engine (8th digit og VIN="P"):
1. relieve fuel system pressure
2. remove/disconnect:
NEG. battery cable
bolts holding fuel filter shield
fuel lines (3 of them) - labeled (1) in above diagram
fuel filter (labeled (2) in above diagram - from its support
Installation is the reverse of removal, but torque the fuel filter shield bolts to 15 ft-lb. (20 Nm).
And, if you're as careful as I am, apply anti-sieze to the bolt threads before they go in.
Engine idles ok slight roughness runs good at top end But mid range speed it's rough and cuts out but will pick back up without completely shutting down
