Computers & Internet Logo
tamtam Posted on Apr 13, 2013
No signal when I hook my Dell XPS laptop to my Element HDTV
No signal when I connect my Dell XPS laptop to my Elements HDTV via HDMI cable. It used to work before but not now...
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 13, 2013
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
464
Points
Turn off tv and laptop. connect the hdmi cable to your tv and laptop turn tv on then log onto your laptop Both devices need to be off when connecting the hdmi cable
Connect cable hdmi
Make sure the laptop has diverted its video to the HDMI port. Try this sequence. Lap top off....TV on...connect HDMI cable. Turn on laptop. Switch laptop video to HDMI if it won't do it automatically.
3answers
I connect my laptop to a projector via hdmi but no display
i connecto laptop my projecto useing display cable but not display
Can record Sky programmes but not view live.
You must connect up the TV to the SKY box, via Audio Visual cables too, in order to watch, recorded programs. You need to hook, up, Component, HDMI, or Composite, You select it by an EXTERNAL channel.
Connect the cable running from the wall into the "In" port on the Sky Box HD receiver. This cable brings in the signal to your receiver. Make sure the cable is securely fastened to the receiver, otherwise you might experience image and audio issues.
Attach an HDMI cable into the HDMI port on the Sky Box HDTV receiver. The HDMI is a single cable that provides both HD audio and video signals.
Plug the other end of the HDMI cable into an available HDMI port on the HDTV.
Power on the HDTV and the Sky Box HDTV receiver. Press the "HDMI" button on the TV's remote control. This will display the cable contents of the HD receiver onto the television.
The receiver is hooked up via HDMI and after about
user cable box hdmi direct access to tv hdmi input if ok ...receiver need replaced...if sam proble need replaced cable box...
4helpful
2answers
Connect my Dell Vostro 1400 laptop to my HDTV via VGA
You have to tell your laptop to use both displays normally it would be the FN + F5 or F6 keys
My dell xps can't connect to my lcd using hdmi cable
Hii
you can use this link
http://www.rockmyhdtv.com/rockmyhdtv/how-to-connect-your-compu.html
It might help you to configure .
If you like this post please rate me .
Thank you
4helpful
Sharp Aquos 46" HDMI problem
I have a similar problem. The Sharp TV aquos appears to be shutting down my blue ray player and dvd recorder when connected via HDMI. They work fine and never close down when I connect them via the rca cables either single video connection or a composite 3 cable rca lead. I have 3 HDMI inputs on the tv and the problem occurs on all 3. Any suggestions?
Xbox 360 hdmi connection to dell W3201C no display
The W3201c IS 720P. You have to adjust the display output on the xbox 360 to 480p then adjust settings up from there...
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
