Power went out, the green light started blinking continuously when power retrurned; green light goes out when reset is pushed by paper clip or when power is withdrawn, but then resumes blinking immediately with power start, even after power was off for 12 hours.
SOURCE: constant blinking green power light but doesn't turn
This is from my WS65907 service manual.
4. Self Diagnostics
The “Power ON LED” provides an indication of the sets operation, and the possible cause of a malfunction.
1. Initial Control Circuitry Check
Immediately after the TV is connected to an AC power source:
• The LED flashes three times ... indicating the Microprocessor has initialized and is functioning
properly.
• If the LED does not flash ... the Microprocessor is NOT functioning.
2. Error Code Operational Check
Pressing the front panel “INPUT” and “MENU” buttons at the same time, and holding for 5 seconds,
activates the Error Code Mode. The LED flashes denoting a two digit Error Code, or indicating no problem
has occured since the last Initalization.
Note: The front panel buttons must used, NOT those on the Remote Control.
• The number of flashes indicates the value of the MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2 second.
• The LED then flashes indicating the value of the LSD (ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: For Error Code is “24”, the LED will flash 2 times, pause, and then flash 4 times.
3. Error Codes
The Error Code designations indicating a malfunction, or no malfunction, are listed below:
“12” ... indicates no error has occured.
“21” ... X-Ray Protect circuit.
“22” ... Short Protect circuit.
“23” ... Horizontal Deflection failure.
“24” ... Vertical Deflection failure.5. Circuit Adjustment Mode
Most of the adjustments can only be performed using the remote hand unit. Many of the adjustments must
be performed in both the NTSC and HD modes. Video/Color adjustments must be performed in the NTSC
and HD modes, and data must be preset in the 480P (DVD) and VGA modes.
SOURCE: the green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
SOURCE: won't turn on after reset ws-55511 hdtv
http://www.techlore.com/forum/thread/19174/Green-Blinking-Light-on-Mitsubishi-HDTV/?page=26#43124
Go to this post. I had the same problem and it was easy to fix...it cost about 26 bucks total and took about 20 minutes start to finish!
Bruce
SOURCE: green light blinks constantly. reset doesn't fix it.
This set has a lot of problems but I have news for you that I recently discovered from a authorized Mitsubishi repair center---
Mitsubishi has had so many problems with this set that now they sell a complete Chassis replacement for this set for about 200 dollars--You will have to go to a authorized center---no more trying to fix individual boards in this set...if you are in doubt--Google the model number and you will see all the problems this set has had---
Contact Mitsubishi and I think the best thing you can do is get the Chassis replaced--
If you have more questions about what I am telling you let me know---I think Mitsubishi is trying to avoid the class action lawsuits that are in progress against them for this model.
REGARDS, SD TECH
Testimonial: "Thanks for the tip. I left it blinking for 2 hours and tried reset again and it worked. But next time i'll use your tip to find the prob."
SOURCE: We recently experienced a power outage, but once
The blinking green light is the DM unit in the set booting up like a computer.
Several things can happen here--Research by model number with GOOGLE, model number and problems.
It is often called the blinking green light of death.
The most common problem is 4 filter caps in power supply (they run 7/24 and supply voltage to DM unit fail--also some fuses there.
If you look on the net you will find places that sell kit for this repair.
This is also one of a group of several Mitsubishi sets with this kind of problem--It is not the Lamp!
Some of these models develop so many problems Mitsubishi now sells a chassis replacement--includes power and several boards that develop bad caps.
Understand: Mitsubishi has a long history of caps failing in their sets, it goes back almost 30 years. I have seen older ones where over 20 filter caps were bad.
You can talk to Mitsubishi to see if chassis replacement is available for your set--this came about as a result of the threat of hundreds of people entering a class action lawsuit (several).
If this told you something you did not know rate this solution as very helpful as I do this here for free.
If you have questions make a "comment" here and I will assist you.
SD TECH
Testimonial: "This is somewhat helpful. I'll contact Mitsubishi. Thanks!"
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
