I was installing Kaspersky One Universal Security and after running the cleanup tool that it has on it, my keyboard doesn't repsond
I found replacing Lenovo Ideapad U510 backlighted keyboard very easy. Ordered replacement online...about $80. Pry up top side of old keyboard with thin tool and tilt up. Remove two connections and reverse process to install new board. Just be careful with pry tool and when disconnection old board. Took me less than 5 minutes.
Try a USB keyboard as a workround. This will allow you to try and re-install the keyboard drivers.
SOURCE: how to fix key on Toshiba Satellite L655-S5061 Laptop Keyboard
The keyboard is made that limited to no service can be done, replacement of the entire keyboard is required. Short term solution is use external keyboard if available.
SOURCE: TOSHIBA LAPTOP KEYBOARD NOT REPSONDING & UNABLE TO LOGIN
In this Case Of Laptops Very sensitive and Costly So Kindly Contact The Nearest Technician Or Service Center One the Laptop Warranty is out Validity then only U Contact the technician
