It depends on what type of ink cartridge you have installed.....with HP genuine ink cartridges and HP Solution center installed, everything should be there. However, if you get an HP
integrated ink cartridge refilled (i.e. HP 60, 61, 74, 75, 901,
92-98....currently offered at Costco or Frys today) or if you buy a
remanufactured/compatible HP ink cartridge, the ink levels will not be displayed nor can they be reset (HP
has a smart chip embedded within the nozzle plate at base of ink cartridge
which counts the drops and then registers as empty).....so you'll just need to
live with it and ignore 'ink low', 'non-genuine', 'counterfeit' messages and
similar while you are using these types of aftermarket supplies. The first
video below provides an overview of the 'low ink' phenomena. NOTE: These types of 'SEVERE' cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem" etc.) typically indicates the internal micro-electronics
of the HP #901 / 901XL cartridge are damaged. The cartridge's electrical wire
runs at rear and lower side of the ink cartridge are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on all models which use HP 901 cartridges. Refer to
Inkjet411 youtube videos below: HP Officejet J4500 J4600 4500 Printer
Error Messages -HP 901 & 901XL Cartridges http://www.youtube.com/watch?v=RivHgvWCkJ8 HP 901 & 901XL Ink Cartridge Alerts -
Low Ink Warnings: http://www.youtube.com/watch?v=hzLM5mlkTt4 HP Officejet J4500 J4600 4500 Printers
Tap 41 Diagnostics - HP 901 Incompatible Print Cartridges: http://www.youtube.com/watch?v=S6uATgXxQlE HP Officejet J4500
J4600 4500 Cartridge Error Bypass - HP 901 Cartridge Errors: http://www.youtube.com/watch?v=I4-m_RLdRE4
HP 901 Ink Refilling & Cartridge Care
Tips - Everything you need to know: http://www.youtube.com/watch?v=jTtNj6rN4g4
SOURCE: where is the ink cartridge located on the HP office jet 6110 prin
if you are to lift the top part of your printer you will see the cartridges inside as shown below:
Lifting the scanner bed exposes the entire paper path and gives your hands plenty of space to replace ink or clear paper jams.
SOURCE: Hp office jet 4215xi how to check ink level
HI
you may get the ink levels in several ways,
1) printing a test page.
2)if you got HP solution Center with the software cd of the printer ans it is installed in the computer,you can easily check the ink levels there.
3)sometimes ink levels option is available in the priner drivers in the printers and faxes in the control panel.
4)right clik the printer icon and then goto properties and then you will find tabs to check the ink levels,it might be in the service this device under the maintenance tab.
Feel free to contact me if there's any query.
SOURCE: I can't get my hp office jet j4580 all in one to
Install full feature printer software using this web link,select your operating system.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&lang=en&product=3645100&
SOURCE: how to reset ink levels from HP J4580 printer
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
SOURCE: setting date and time on
Set the date and time
On the product control panel, press Setup (
Press the Left ( ) or Right
( ) Arrow button to select Basic Setting , and then
press OK .
( ) Arrow button to select Date and Time , and then
press OK .
After Enter
date appears on the control panel display, use the keypad on the control
panel to type the date in the correct two-digit format, MM-DD-YY (01-01-10).
After entering the date, press OK .
After Enter
time appears on the control panel display, use the keypad on the control
panel to type the time in the correct two-digit format, HH:MM (10:15), and then
press the Right ( ) Arrow button
to switch between AM and PM . After entering the time, press OK .
