D-Link DIR-625 (790069292637) Wireless Router Logo
Posted on Mar 09, 2009
Error code 109 D-Link Router DIR 109
I've set up my D-Link woreless router up correctly according to the set-up. Before I get to the end an error code pops up ''error 109''. If I close it out, my laptop connects to the router, the signal strength is excellant, but it won't connect to the internet. What can I do?
CampinFamily
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Mar 12, 2009
CampinFamily
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
4924
Points
26
Can you connect to the router interface? what does it say the wan status is?
I can't install the cd d'link dir-100 it says that error 321 ethernet cable not onnected
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for more information about the routers and network
1helpful
Cannot connect to internet
what operating system?
what is the error?
is this woreless or hardwired using ethernet?
check the browser settings, check firewall settings and applications that may interfere with the connection if wireless check network security issue and the router settings or the modem.
make sure that the correct security key is correct and the same with the computr and the router ............ try updating drivers on teh computer reset router on issue ... ^_^
1helpful
Hi , I keep getting an 'error 109' at the end of my router config. What do I do??
I think you are trying to install the router using the CD.
But you can install the router without the CD also.
If you connect the computer to the modem , does it works ?
If it works then modem is working. now connect the computer and modem to the router.
open the set up page of the router. change the Internet settings according to the ISP.
Click Here for more information about router and networks.
When setting up my new D=Link wireless router I get an error message 302 internal error router setup can not continue I can connect on my old router . What does this message mean?
I called the D-LInk support number . The technician was extremely rude and of no help . It was so bad I returned the router to the store and bought a Linksys router. It was easier to install and works great.
1helpful
D Link DIR-300 - Connection was Reset - Unable to set up router
press reset button for 10 seconds then all settings are defaults.
you can access your router witrh following link
http://192.168.0.1 or
http://192.168.1.1
109 INTERNAL ERROR
try to login to the router, plug the router in directly into the laptop and go to 192.168.1.1 and login and see that the settings are setup correctly and also try to set the wireless with all things off with the settings set to DHCP
If you need further help, reach me via phone at https://www.6ya.com/expert/david_eb7ea98642566cc6
1helpful
Error code 302 thats that mean?
HTTP 302 is not an error. It's simply a request for your browser to redirect to another URI. Browers aren't supposed to show you a message, they are supposed to simply follow the redirect. You should try accessing the router interface from a different web browser, such as Firefox.
1helpful
Dlink WBR 1310 error 109 internal error
Remove the CD setup. Try calling your Dlink Manufacturer to help you install the WBR-1310 manaully.
2answers
Linksys Wireless G Router Set up
I ended up loading the router setup cd onto another laptop, and it worked fine. I still don't know why the first laptop had the error code, but they now both, work perfectly fine. Thanks, anyway.
What is Error 109
Hi
here is what i found for you-
PartitionMagic or PartInfo reports Error 109: "Partition ends after end of disk."
go to this link and click HERE
if you have a dlink router try going to this forum THIS
hope this helps
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
