U0073
Control Module Communication Bus Off
Digital Signal Processor
REFER to Section 418-00 .
U0073
Control Module Communication Bus A Off
EATC Module
U0073
SJB
U0073
TCM (FNR5 Speed Transaxle)
REFER to the Powertrain Control/Emissions Diagnosis (PC/ED) manual.
U0073
TCM (6 Speed Transaxle)
Your best bet , take it to a qualified repair shop . You do not have the knowledge or diagnostic test equipment to diagnose this . Do you know what C.A.N. - controller area network is ?
Communications Network
Vehicle communication utilizes both medium and high speed controller area network (CAN) communications. CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 2 module communication networks:
Medium speed (MS) CAN
High speed (HS) CAN
Both networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on both networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
P0020 - Intake Camshaft Position Actuator Circuit/Open (Bank 2)
Description:
See the description for DTC P0010.
Possible Causes:
See the possible causes for DTC P0010.
Diagnostic Aids:
See the diagnostic aids for DTC P0010.
Application Key On Engine Off Key On Engine Running Continuous Memory
All
GO to Pinpoint Test HK .
Do you know about communication networks or serial data communications on vehicles , these let the scan tool communicate with the different modules on the vehicle ! Newer vehicles have several, PCM - powertrain control module , Anti-theft module , Air bags , antilock brakes , Body control module or in the case of ford a smart junction box . an some others !
Vehicle communication utilizes both International Standards Organization (ISO) 9141 and controller area network (CAN) communications. ISO 9141 is used for diagnostic use only, and CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
The vehicle has 3 module communication networks:
ISO 9141
High speed (HS) CAN
All 3 networks are connected to the data link connector (DLC). This makes diagnosis and testing of these systems easier by allowing one scan tool to be able to diagnose and control any module on the 3 networks from one connector. The DLC can be found under the instrument panel between the steering column and the audio unit.
HS-CAN Network Operation
The HS-CAN network communicates using bussed messages. The HS-CAN network uses an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The HS-CAN is a high speed communication network used for the following modules:
ABS module
4WD control module (if equipped)
Instrument cluster
PCM
MS-CAN Network Operation
The MS-CAN network communicates using bussed messages. The MS-CAN has an unshielded twisted pair cable, data bus (+) and data bus (-) circuits. In addition to scan tool communication, this network allows sharing of information between all modules on the network.
The MS-CAN is a medium speed communication network used for the following modules:
Instrument cluster
SJB
HS-CAN Network
What type of scan tool are you using ? or are you using a code reader ?
Do you know what a serial data network is ? With all the computers car makers put on thier cars these day's they need a communication network for them to talk ,share info. on etc. U codes are codes for the network . A module could be down ,could be a wiring problem . A shorted module or bus wire can bring down the whole vehicle. Could cause the vehicle not to start ,systems not to function . How did you pull this code ,with what scan tool or code reader ? Did it come from the PCM - engine computer ? Need a up scale professional scan tool to check all module's on the vehicle , need to pin point the module that is causing the problem .
U1900
CAN Communication Bus Fault - Receive Error
4WD Control Module
REPAIR all other DTCs first. CLEAR the DTCs. CYCLE the key OFF then ON and wait 10 seconds. REPEAT the self-test. If DTC U1900 is still present, REFER to Section 418-00 .
U1900
ABS Module
U1900
DSM
U1900
Instrument Cluster
U1900
Occupant Classification Sensor Module
U1900
Parking Aid Module
U1900
RCM
U1900
Retractable Running Board Module
016 CAN Communications
SECTION 418-00: Module Communications Network
2007 Explorer/Mountaineer/Explorer Sport Trac Workshop Manual
DESCRIPTION AND OPERATION
Procedure revision date: 08/02/2006
Vehicle communication utilizes both medium and high speed controller area network (CAN) communications. CAN is used for many modules to communicate with each other on a common network. CAN in-vehicle networking, is a method for transferring data among distributed electronic modules via a serial data bus. Without serial networking, intermodule communication requires dedicated, point to point wiring resulting in bulky, expensive, complex, and difficult to install wiring harnesses. Applying a serial data network reduces the number of wires combining the signals on a single network. Information is sent to the individual control modules that control each function.
High speed (HS) CAN
Network Topology
Module Name
Network Type
Termination Module
Anti-lock brake system (ABS) module
HS-CAN
No
Audio control module (ACM)
MS-CAN
No
Digital versatile disc (DVD) player (if equipped)
MS-CAN
No
Driver seat module (DSM) (if equipped)
MS-CAN
No
Electronic automatic temperature control (EATC) module (if equipped)
MS-CAN
No
Four wheel drive (4WD) control module (if equipped)
HS-CAN
No
Instrument cluster (IC) (gateway module)
HS-CAN
MS-CAN
Yes
Yes
Occupant classification sensor (OCS) module
HS-CAN
No
Parking aid module (PAM) (if equipped)
MS-CAN
No
Powertrain control module (PCM)
HS-CAN
Yes
Power running board (PRB) module (if equipped)
MS-CAN
No
Restraints control module (RCM)
HS-CAN
No
Satellite digital audio radio system (SDARS) (if equipped)
MS-CAN
No
Smart junction box (SJB)
MS-CAN
Yes
Transmission control module (TCM) (if equipped)
HS-CAN
No
SJB
Audio unit
Instrument cluster
DSM (if equipped)
DVD player (if equipped)
EATC module (if equipped)
Parking aid module (if equipped)
Satellite audio receiver (if equipped)
Power running board module (if equipped)
PCM
TCM (if equipped)
RCM
ABS module
Instrument cluster
Occupant classification sensor module
Network Termination
The CAN network uses a network termination circuit to improve communication reliability. The network termination of the CAN bus takes place inside the termination modules by termination resistors. Termination modules are located at either end of the bus network. As network messages are broadcast in the form of voltage signals, the network voltage signals are stabilized by the termination resistors. Each termination module has a 120 ohm resistor across the positive and negative bus connection in the termination module. With 2 termination modules on each network, and the 120 ohm resistors located in a parallel circuit configuration, the total network impedance, or total resistance is 60 ohms.
Network termination improves bus message reliability by:
stabilizing bus voltage.
eliminating electrical interference.
Gateway Module
The instrument cluster is the gateway module, translating HS-CAN to MS-CAN and vice versa. This information allows a message to be distributed throughout both networks. The instrument cluster is the only module on this vehicle that has this ability.
THE LINK ABOVE GIVES THE SPECS
MSI K9MM-V (MS-7312) Spec Sheet
Powered by MOBOT
Part Number
K9MM-V (MS-7312)
Manufacturer
MSI
Price Check
Find Best Price
Downloads
BIOS Drivers Manuals
Chipset
VIA K8M800 VT8237R+
North Bridge
VIA K8M800
Socket
Socket AM2 (940)
Processor Types
Athlon 64X2, Athlon 64FX, Athlon 64
Number of CPUs
Front Side Bus
800MHz HyperTransport Bus Link
Memory Type
DDR
Memory Channels
Dual
Maximum Memory
2GB
External Graphics
AGP8X
IGP
VIA UniChrome Pro
South Bridge
VIA VT8237R+
Audio
6-channel
IDE
SCSI
None
SATA
1.5 GB/s
RAID
LAN
Firewire
None
USB
USB 2.0
Expansion Slots
BIOS
AWARD
Form Factor
microATX
control panel admistrive tools,computer management,device manager scroll down universal serial bus controllers you should see a yellow question mark? right click to reinstall drivers
hey which window u use in pentium, means in ur pc try this sigmatel sound driver.its very best for "pentium r Dual CPu 1800.0 MHz (70 x 257.1 MHz)" so keep enjoy if then u have any other problem then tell me
