I have a combination of problems and am wondering if they are all coming from the same source. basically the fridge stopped working there is no cold mist coming from the freezer compartment. Also the ice machine has stopped working and there is a build up of ice at the botom of the freeze rAt the moment i am defrosting the freezer beacause there is a build up of ice everywhere which i presume means that the defrost controller is faulty ?? so hoping a total defrost might make thiwork again. Hope someone can help,thanks
If it starts working ok after the defrost then you might find it will build up ice again.
There might be a fault with a small device called a thermister that senses the ice build up for the defrost controller.
What most likely is happening is the ice build up freezes the fan that blows the cold air to the fridge compartment.and around the freezer.
SOURCE: bosch frost free fridge freezer not freezing ice cream/pops at all and meat not totally frozen
Sounds like a defrost problem. Check to see if
there is any frost buildup in the back wall of the freezer. If so, it is not
defrosting as it should.
If
you don’t know what these are then unplug the machine and let the ice melt in
the freezer overnight with the door open. Then try it the next day, if is
cooling fine then you need to have a service person replace one of the above
items. If it still has a problem then it might be the compressor and you should
probably replace the machine.
SOURCE: Bosch Classixx Frost Free KGU34640GB/06
the freezer is not defrosting at all .How to defrost it ?
SOURCE: frost free fridge freezer has
yes,
you have a defrost problem, three things..
one, defrost heater could be bad,
two, bi-metal could be bad,
and three, the timer could be bad.
any of these three items getting bad would result to one symptom.
ice buid up at the bottom of freezer section.
tnx 4 using fixya,
drcool
SOURCE: bosch fridge freezer - ice build up and water leak from freezer
This is most likely a blocked drain pipe - blocked with ice that is.
Remove all the drawers in the freezer - and stack them up.
With the unit switched off and unplugged, undo the fixings on the rear pannel in the freezer (behind the drawers)
Remove it to see the evaporator coils etc.
At the base there should be a channel - and a hole leading to the drain pipe. This needs unblocking wih a thin flexible cable. -net curtain support wire is ideal, and cheap. or use a short length of insulated cable.
Check it comes out at the rear of the unit onto the evaporator container - situated on top ofthe compressor.
Replace everything and switch on.
SOURCE: Bosch intelligent frost free 88
We have the same and I think it is because the freezer door bounces open when we shut the fridge door. Then the freezer compartment ices up, the fan clogs up with ice and cannot blow cold air into the fridge, and the fridge gets warm and the milk goes off.
Solution? We have bought one of those child safety clips (search for fridge safety clip or lock) to hold the freezer door closed.
Simple design error. Expected better from Bosch :-(
Check
out these tips...they can help you figure out what is going wrong
with your refrigerator and why it is not cooling
Refrigerator
not Cooling
or Fridge not Cooling
How to Defrost Refrigerator Defrost
Timer Problem
Water
Running in refrigerator
from Freezer
Refrigerator
or Freezer not Cooling or Getting Cold
heatman101
the feezer makes the normal noise when its on
