If you just want to get through the smog test,they usually allow one monitor test to be incomplete and still pass.
If your area does,clear the codes and fill the fuel tank to the top.The other monitors should run and complete but the fuel tank monitor will not run with a full tank of gas so will not turn on the check engine light related to a tank vac leak.KEEP THE TANK FULL,and go get your smog test!
SOURCE: saturn code p0442, evap system small leak, can't find leak
I would send the car in for a smoke test...So much easier to find the leak...
Testimonial: "found another definitation for a code 422. replaced rear o2,fixed"
SOURCE: Smell of gasoline fumes at rear of car but no
It sounds like either your fill line or vent line has a small hole in it. Check the hoses for cracks or pinholes and the steel pipes for rust (again, pinholes)
