if you forgot your pattern lock, just give few more tries to continue wrong efforts. at an instant, the OS will report 'attempts exceeded, enter with your gmail'. at this point just enter your email address and in the textbox for password just give value as 'NULL'. this will instantly ask for new pattern lock and you are done!
You need to reset phone. Hold green,red and volume down at same time with phone off. Make sure that if you have a memory card that you take it out first. This will clear the lock code and reset your phone to factory settings.
After you put the pattern in a few times incorrectly it will lock the phone and an option at the bottom will appear that says "Forgot Pattern?" Select that and enter your email and password to unlock the phone.
lock screen pattern and gmail password is not related. but if you forgot the lock pattern u can reset or disable it with gmail id and password. If you draw the incorrect pattern five times you will get a message press OK. u can see a new button on screen below the pattern named "forgot pattern?". Touch this button to reset or remove the pattern with gmail id and password.
IDK about a simple legitimate fix for this. I was just messin around with the pattern, hit "forgot pattern" to see what it does. It asks me for the Google username and password, but has no way for me to go back! I know the pattern! The Motorola Droid is free from this problem, when on the forgot password screen, it still allows me to go back to the pattern screen. Very disappointing HTC...
On the other hand, there is a bit of a "hack" that can be used to solve this. Create a new Google account. Then call the locked phone from another phone. While in the call, you have full access to the phone. Press home, go into your settings, and add your new Gmail account into the phone. End the call, go back, and enter your new Gmail info. You may also need to enable Wifi while the call is still connected, I'm not sure if 3G will work for the sync while the phone is "locked".
