When I plug it in and try again, I don't even get a message or anything. The screen on the camera goes black and the red light is blinking.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use iPhoto or any other photo cataloging program.
SOURCE: olympus fe-130
Make sure your cable is OK. 1: Make sure you don't have any damaged pins on the plug on your camera and on your USB port on the computer Try using a different cable to be sure that is not the problem. If you can t ry a different camera on the same cable and make it work, your camera is at fault. Try it on a different USB port, and possibly also on a different computer to make sure the port on your computer is not at fault. Check both cable ends and the ports on the camera and computer are not dirty
SOURCE: olympus stylus 790 sw:windows vista does not recognise the devise?
there is none, olympus shld bl00dy fix the problem
SOURCE: olympus stylus 790 sw -
With a screwdriver scrape the 3 contacts of the battery, it works for me
SOURCE: my Olympus Stylus 1050SW will not connect to my pc
Do what the pros do...use a card reader instead of your camera.
SOURCE: USB cord (for Olympus Stylus 790) not recognized on computer
Hello :
The problem is not with the cord . But it's with the computer .
I'll give a solution assuming that you are using [ Windows XP ] as an Operating system . This can also go with [ Win 7 or Win Vista ] .
1: Go to start
2: Go to all programs
3: Go to accessories .
4: Go to system tools .
5: Click on [ restore ]
Now you will see many restoring points . Try to remember which point or time the ( Olympus Stylus ) was working fine .
6: You need to restore your system to that point or time .
7: The system will restore itself to the point you chose and will reboot .
8:After rebooting plug in your Camera USB cable to try if that worked or not . It should work . If not , then the problem is with the Camera . For that you need to reset the Camera and try again .
If that didn't help , then there must be a hardware failure with the camera and it needs to be serviced .
Please don't forget to rate !
good luck .
