SOURCE: Tag Heuer Aquaracer calendar problems
You have to unscrew the knob first then you will be able to pull it out to change the minutes, hours, date. You may have to use a pair of small pliers to initially turn the knob.
SOURCE: Change the date on my TAG Watch
if it has hands the winder will be screwed in undo this anti clockwise then click it out once for date twice for time, if this helps please rate me joe
SOURCE: Tag Heuer - Aquaracer automatic (Day/ Date)
Actually in the realm of things that is close to midnight. But if you want this changed you will have to take it to a watch repair person because the movement will have to be taken out of the watch and the hands pulled and rest to change when the calender flips over. When I set up watches i usually have the day/date flip after 2 am so that most people never see it change ( because they are asleep lol)
SOURCE: Tag Heuer WK1110 Date Changing Problem
This could be caused by a couple of things. To fix this would require a qualified watchmaker to repair. The watch will need to be taken apart and the dial and hands will need to be removed to repair this problem.
Normally when we see this problem one of the wheels needs replacing. This can be caused by manually changing the date near midnight.
Let us know if we can help more.
Ken
Yellowstone Watch Inc.
SOURCE: how can i make the date of my tag heuer formula 1
To s e t t h e t i m e a n d d a t e
Your TAG Heuer chronograph is fitted
with a screw-in crown and safety seals
which guarantee it to be waterproof
to 200 m (660 ft).
Position 0: Crown is screwed in
(normal position).
Important: The crown must be
screwed in correctly to guarantee
the water-resistance of the watch.
Position 1: Crown unscrewed.
To change the hour (change of time
zone) or date quickly, unscrew the
crown, pull it out to position 2 (quick
corrector) and turn it in either
direction. This mode allows you to
change the hour and the date without
any loss of minutes.
The date changes each time the
hour-hand passes midnight.
To set the time, unscrew the crown,
pull it out to position 3 (setting the
time) and turn it in either direction.
After setting the date or the
time, push the crown back and
screw in to position 0.
