On the days end report there are listed 4 voids. I am trying to figure out the differences between them and which keys create which voids. In the report they are listed as - VOID; SBTL VD; (which doesn't seem to be a sum of the voids); MGR VD and lastly VOID That is printed much larger and bold Thanks for your help
SOURCE: When the VOID key is used, it automatically
yes it will ....only if the cash drawer is not open
SOURCE: i have a XE-A404 cash register, ive been out the
SOURCE: The mode switch stays on
The units built in protection circuit might be faulty or needs resetting, this unit is operated by a rechargeable battery, try charging the batteries, you can do that by switching the mode switch to any position other than OFF, then plug in to ac outlet, charging the batteries may take up few hours up to two days, depending on batteries and their charge level,
for more info, try reading through here,
http://www.cashregisterhelp.com/files/cas_man_XEA404.pdf
