The cable for the sansa fuze seems to fit but and I plugged the usb end intot my computer and mac and got a warning that the usb port was over charging
If you get an error message "Insufficient power to operate USB device" when you plug a USB device into the computer's USB port or the un-powered USB hub that is attached to the computer's USB port, then this device is drawing excessive current that the USB port cannot supply. The maximum output from an USB port is 500mA. In case such as this, you need to purchased a powered USB hub and connect this hub into the computer's USB port and then connect the USB device into this powered USB hub.
SOURCE: phillips go gear stuck on Repaired all contents cleared!!!
i held the volume+ button in while i plugged the usb cable. the computer recognized new hardware was found. i opened the phillips device manager and hit the repair tab. it automatically ran a repair through the mp3. then i installed new firmware through the phillips device manager. i lost all my contents but windows media 11 sync all my music back. THANKS ANYWAY!!!!
SOURCE: lost software for my Phillips GoGear
www.usasupport.philips.com
enter country/language
entry model number
click on model #
click on software & drivers
-Tha Mp3 Doctor
SOURCE: My USB cable can't be read
Upgrade the firmware by downloading the latest version of the Philips Device Manager from www.usasupport.philips.com and clicking on the Update tab.
-Tha Mp3 Doctor
SOURCE: I try to download songs, but AutoPlay keeps popping up.
Test another USB port on your computer, and see if you get the same result. If you get the same result, the USB cable may be faulty.
Here is a test you can do to see if the problem really is the USB cable, or if it is something else:
Triple Reset for Philips’ GoGear:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
After repair is complete, upgrade the firmware for this player. Will erase all the songs, but you should be good to go again.
-Tha Mp3 Doctor
