SOURCE: cant get my wireless connection to work not sure
To enable/disable WLAN, please press "Fn+F11" to execute the device: (then follow below steps accordingly)
Note: there are four stages in all, assumingly both bluetooth and wifi are installed.
First stage : press Fn+F11 = Enable WLAN only
Second stage : press Fn+F11 = Bluetooth On + WLAN Off
Third stage press : Fn+F11 = Bluetooth On + WLAN On
Fourth stage press : Fn+F11 = Bluetooth Off + WLAN Off
After enabling the WLAN, search the Access Point and connect with it. Now, you may use the WLAN.
If this does not work, check if the driver is installed in your computer by going to the device manager. check under network adapters. If the driver is installed, uninstall the current driver and restart the computer.
If the issue still persists, you may download the driver update at the msi website: http://www.msi.com/index.php?func=nbdriver&maincat_no=135&prod_no=1474. Just make sure the driver you're downloading is compatible with yoru operating system
SOURCE: can't find the wireless antenna on my msi u100 series laptop
Not really sure what you are expecting. The wireless antenna is within the computer--you won't see it.
What you will need to do is to turn the wireless networking on. This is done in some computers with a small switch on the case (in this case, there is usually a light that comes on when you turn the switch on). In other cases, you will have to use the Fn key plus one of the special function keys at the top of the unit (has a picture representing a wireless connection on it--possibly something like an antenna).
If this fails, go into your network connections and see if the wireless connection is actually turned on. If you have Vista, this is sorta easy as you click on "connect to" and then choose "wireless network"
SOURCE: u100 msi wind netbook, webcam problems
i have same problem pls sant driver u100 webcam [email protected]
SOURCE: How do you turn on wireless capabilities of the
Press the Wireless lan button on the top right of the keyboard
reference manual sourced
SOURCE: hi just got a msi
press and hold the Fn key then tap the F11 key and it should show the wireless icon in the bottom left corner
thank you for this helpful sites. And thanks to Melanie Mejia, you fix my wifi network MSI N014 laptop
