The light can come for a few reasons. Not emptying, not filling, over filling or water leaking into base.
Probably jug impellor part number (424099) from espares, buyspares or bosch direct.
No fix unfortunately, this problem manifests as unit starts to fill and motor does not switch on. Eventually the unit overfills and the pump and fill start to alternate and check water light comes on. If this is the fault then this part is the solution it runs in line with the inlet valve and side fill chamber, take the left side panel off (looking from the front) it is tucked away behind the hoses bottom left. Check water light can also come on if the unit is not pumping, if this is the case, repost and I will try and talk you through clearing this fault.
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
