Power off the machine wait ten seconds then power on holding down the stop key button. If the code comes back get a new fuser unit, continue to reset with out new fuser could cause a fire that would ruin a perfectly good day!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
SOURCE: how to reset error c0500
The error code means that the fuser is not warming up correctly. There is a small black rest botton on the main controler PCB on the back of the copier. You are going to have to take the back cover off, I believe in is four screws. Turn the power off and remove the back cover and find the small black botton, once you have found it, turn the copier back ON and press the botton and see if the error code can be rest. If it dose you are good to go... If not you may have to replace the fuser unit..... I did have a problem that was not solved with the fuser unit.. It turned out to be right side door switch... I would look there as well with the back cover off... Good Luck
