The fan runs and turns off as though it is working, but there is no water in the bucket. I tried washing the filter (although the filter light wasn't on) and I also unplugged it and let it set for several hours to see if it would reboot but still, it is not removing water and the fan is still running intermittently. It is only about 2 years old and is used in a finished, heated and air conditioned room in our basement.
SOURCE: I have a FDL70S1 Dehumidifier.
Dont spend to much time trying to repair dehumidifier they are very cheap to replace. Most dehumidifiers have lots of problems because they are made so cheap. Just replace the dehumidifier you will tank me in the end.
SOURCE: I have a 2 year
Don, unless your dehumidifier is a Low temperature model, that very well may be the problem.
The air temp in a basement at floor level is colder than that chest level. Dehumidifiers don't work well at temperatures at 40 degrees F or less. Raising the unit up off the floor on to a sturdy table, counter top, etc, that is strong enough to handle it's weight, plus a full tank of water, will generally solve the problem. The higher up you can safely put it, the better. Also, lower the humidity extraction level to 35%. As 50% is just not low enough in a basement application.
Hope this helps you to solve the problem.
SOURCE: My dehimidifier is two years old in my basement.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
If you have a dehumidifier that is not producing any water
then you are wondering what you need to do to get this thing to work
for you. In some cases you may be able to do something and in other
situations there may be nothing that you can do.
If you do not hear the compressor running and the unit says that the humidity in the room is higher then the setting, then you have a problem with your dehumidifier.
A few things that can cause this are:
The circuit board relay has gone bad...replacement of this board will often cost more then a new unit. This also is a very common problem with many dehumidification units.
The compressor has failed...if
you hear a buzz for a few seconds, every few minutes, then you have a
bad compressor or at least bad start components on the compressor.
Either way it again is a costly repair.
If the compressor is running and the coils are not getting cold then you have a refrigeration system leak. Recharging or fixing these units is very difficult and is another costly venture compared to the price of a new dehumidifier.
If the compressor is running but the fan is not, this also will cause low water production and continual freezing of the coil.
If the compressor and the fan are running but the coil is totally blocked then you will get no water production. Air needs to be continually moved over the cold coil to get the water out of the air.
If nothing is running, then you may also have a control board failure. Or the humidity sensor or humidistat has gone bad which tells the machine to run. If the sensor says that the humidity is low enough then it will never run.
Also if nothing is running check the float switch or the bucket switch.
Many of these switches are very touchy and if you do not have the
bucket in place just exactly right it will not trip the switch to allow
the unit to run. These switches often are more fragile then they should
be and break easily. The good thing is that when available they are easy
to replace and relatively inexpensive.
There are some parts
available for a few brands, but with the prices for most of the parts
that you can replace running anywhere from 40.00 - 80.00 dollars,
replacement parts with labor to install them, makes a repair more then
the few hundred dollar cost of many of these dehumidifiers.
As
you can see there are quite a few things that can cause your
dehumidifier not to work. Systematically go through the list and
eliminate things to get to the bottom of the issue causing your problem
and then decide if it is worth spending the money to try to fix the old
unit. Only you can make that decision.
