SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
SOURCE: Element will not turn off
Sounds like the contacts inside the switch have welded themselves together. You will need to replace the switch. (the one that you mentioned "clicked" to off) If you like, post an Ask Me with your full model number and I will look up the part number for you. This is a fairly easy repair.
SOURCE: Glass cracked on smooth top stove would like to
Usually short instructions come with the glass. Just be careful about the wires not to pinch them tween the new glass and the frame. Use the type sealant they recommend.
SOURCE: need to replace glass top on a frigidaire eletric
Were you able to find a replacement part? I have the same problem, and am having difficulty finding a replacement.
SOURCE: Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
