Im using the cable but its not conecting to my computer
SOURCE: fuji j10 - my mac wont recognise it even using finepix
I had the same problem with my camera & mac. I got this off the Fuji site and it worked for me:
If images cannot be downloaded from the camera to a Macintosh, check the status of the camera and the Macintosh and resolve the problem accordingly.
1) Check the status of the camera and Macintosh.
1. Connect your camera to the Macintosh and turn the camera on.
2. Open the "Applications" folder on the Macintosh HD.
3. Double-click "Image Capture".
* If the "Imaging device not connected" message appears, follow the steps described in [Checking the connection between the camera and PC].
4. Select "Preferences" from the "Image Capture" menu.
5. The procedure for using the Image Capture Preferences window differs depending on the OS version used. Use the correct procedure for your version of Mac OS.
- Mac OS 10.4: Click "General" in the Image Capture Preferences window.
- Mac OS 10.3: Click "Camera" in the Image Capture Preferences window.
- Mac OS 10.2: Simply proceed to the next step.
6. In "Items launched at camera connection", select "FPVBridge" and then click the [OK] button.
* If FPVBridge is not among the displayed items, follow the steps in [Displaying FPVBridge] below.
7. Quit "Image Capture".
If you implement the above procedure up to step 6, FinePix Viewer launches automatically.
* To stop FinePix Viewer from launching automatically, follow the steps in [FinePix Viewer Setup] below.
SOURCE: Need Fuji FinePix A500 Software
Go to their website, Its a whole lot easier just to get a external card reader or use one thats built in your pc if you have one...
SOURCE: I have the fuji finepix
Take out the Camera software.
Then restart the computer
Let Windows do it all by its self
SOURCE: Help!!!i lost the software that came with my fuji fine pix S6500
hi.
here's the direct link for the S6500fd photoshop plugin download from adobe. photoshop should open raw after you've installed this:
http://download.adobe.com/pub/adobe/photoshop/cameraraw/mac/3.x/DNG_Camera_Raw_3_7.dmg
Here's the adobe downloads centre link in case you need to check up on everything & the installation instructions.
http://www.adobe.com/support/downloads/thankyou.jsp?
Cheers Andy.
SOURCE: Fuji FinePix F30 shutter problem: won't take pictures
Its fairly easily fixed and its a common problem with the F30. The
shutter button contact slides off upon impact when dropped, it must be
re-aligned so that it makes proper contact and performs normally. All
that is needed is the special screw driver for the F30 (easily
purchased online, just google it: "screw driver for fuji f30" ) or
bring it to your local watch/jewelry repair store and tell them to open
it up for you.
We have two F30's and they both have been
dropped, both did the same thing with the shutter button. But both were
easily fixed. Always keep the camera in a safe place and away from
kids, they are very sensitive devices. Use the wrist cord when taking
photos.
