HP LaserJet 4345mfp Printer Logo
Posted on Mar 08, 2009
Hp 4345 mpf - offline
How do I put it back on line to use as a printer.
Anonymous
Level 1:
  • Contributor 24 Answers
  • Posted on Mar 08, 2009
Anonymous
Contributor
Level 1:
Answers
24
Questions
Helped
16591
Points
39
Friend,
If the printer's display just says "Offline" yuo should push the Sleep button on the front panel and you're done. If the message occurs in the printer driver instead, you could try to disable BiDirectional support in the driver.
//Al
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
2answers
How to put printer back online
Try the steps listed here. It is a pretty solid troubleshooting guide for a printer showing as offline.
HP Deskjet 6980 won't print. Says offline but i don't see how to turn it back online. was working. now not.
Printers often go off line for no reason. It can be genuinely off line or the pc is just not seeing the printer anymore To put it back on line all you need to do is open the print queue (double click on the printers icon in printers devices/ printer and faxes) go to File and in the drop down list it will say "Use printer Offline or Use printer online. click on it and if the pc is seeing the printer if will change and the printer will then start up and print. If this does not work then check your cable to the printer or your network connection to reestablish the connection.
HP PRINTER C7180 : PRINTER IS CURRENTLY OFFLINE WHAT DO I DO TO PRINT MY DOCS
hello aang.... open up the print menu and click on the off line spot. that will put it back on line once again. j.
5helpful
Hp LJ 4345 mfp vertical line down printed copies
Dirt.
Open the ADF, the top of the scanner/copier.
The ADF glass is the thin strip of glass on the left. Damp cloth with windex or any glass cleaner. Scrub the strip of glass.
Setup hp 4345 printer but its says offline
right click on the printer driver and select use printer online if its not working check the connection .. replace the cable and check it
3helpful
Can't print. message load MPF won't go away
There is a print job waiting, either in the printer's memory or on your computer's memory. This print job is set to go to the Manual Paper Feed (MPF) which is accessible from the front of the printer by flipping down the little MPF door.
You can change settings for new print jobs, but once one job is submitted with "Please Print Me On The MPF" set, there's no way to change that job.
The easiest fix is to put some blank paper into the MPF and let it print out.
If it's spooled on the printer, you can turn the printer off and back on again to clear the job.
If it's spooled on your computer, you can view it by bringing up the Printer settings:
Start->Settings->Printers and Faxes
Find your 3100 and double-click on it.
Find the print job, select it and pick "Cancel" from the "Document" menu.
1helpful
2answers
HP 4345 Dark Line in Middle of Scanned Image
The correct answer is to clean or replace the mylar sheet on the bottom of the adf
3helpful
3answers
Laserjet 4345 mfp paper jam
13.20.00 can be also caused be a jam near the fuser (the part of the printer that gets hot to make the toner stick to the paper). Remove the toner cartridge and take a look for small scraps of paper along the whole path. Also open the door on the back of the printer and look for paper scraps from there. If you see paper stuck in the fuser, do not use anything sharp to remove it, be careful not to scratch the surfaces.
k24674
Grand Canyon Tech
Grand Canyon Tech
