SOURCE: how do i get the
Hi
had this problem too!! they didn't tell you this in all the instructions! it took me a while to work it out.
What you have too do is when you start the game and you are actually in the game, (you are past the advertisment bit) you have to have your bike switched to gamecube as your lead is connected to the game cube section. you can then have to select the game cube remote this means you can use the bikes controls rather than holding the wii remote.When you have clicked on the game you want you then have to switch the bike back to the cyber bike you can then pedal doing it this way seems to set the bike for use.
i have tried many combinations and this has worked!
the switch i am talking about is the switch on the main part of the bike controls at the bottom in front of you!
good luck i hope this made sense and it works for you!
SOURCE: do i have to use
Hello Tatyana, You mostly need to steer and use the pedals. Depending on the game you play you may have to use some of the buttons - for example, in the Cyberbike original game you can use the a button for jumping over obstacles. You can also use the break to slow you down.
Please note that we do not monitor this forum regularly you can ask us questions directly at [email protected]
