-dr error message -door light on the control pannel is on continuously -door will open -oven and broiler will not work -if off button is presses for 30 seconds the stove begins to beep and there is an F11 error message -have tried to unplug from the power for various lengths of time to reset
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
SOURCE: F93 error. Oven door is stuck, won't open.
Hi
Thanks for using FixYa. F93 code means "Maximum oven door lock
time exceeded." Actually it's trying to lock the door but is not aware of
the time to stop. Please check the micro switch and lock’s motor. Replace
whichever has gone bad. To reset it turn it off for more than 10 minutes and
then turn it on.
Please do rate the solution and
revert for further assistance.
Thanks
Rylee
SOURCE: Oven Lock stuck open before start of self-cleaning cycle
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
SOURCE: Oven locked so I can't shut door/operate oven
Thanks a million, solved the problem like a charm. For those that can't find it, it is on the left side orf the OVEN, not the stove. Once you open the door, you'll find it on the frame's upper left side corner, can't miss it. Good luck
SOURCE: I have a gas stove - Frigidaire model FGF326ASA.
You probably have a weak ignitor. To operate properly it should draw 3.5 amps or better. The ignitor must be bright. If it is dim it is weak.
Some repair pix
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Testimonial: "Thanks for the help, much appreciated. Ignitor was coming on but not pulling full amperage. Am going to replace ignitor."
SOURCE: I have a frigidaire mef352bgwd electric oven-
There is a pin that tells the oven the door is open, you need to push it in an hold it. It is pretty stiff, you can't use your bear hand. It will be in the upper left of where the door closes.
