The printer's network connection light is steady green. I cannot connect the printer and the computer, wirelessly or even wired. I had no problem connecting the printer wirelessly before when I had Windows 7. I have tried following the original instruction manual published before Windows 8. I have tried following the Windows 8 notes from Lexmark's website. When I get to the point where it searches for the printer, it does not find it. Help Please.
SOURCE: Lexmark X4850 Wireless wont connect
Had a similar problem with my router, which was a 2WIRE router (furnished by AT&T - I have Uverse). Fixed it by going to the router's GUI (mine is 192.168.1.254), click on "View the home network". On the right side of the resulting screen, there is a section titled "wireless settings". Under that, click on "edit settings". Enter the login information (the default password is on a tag on the router). The next screen is "Configure the Wireless Network". Scroll down to the bottom and click on "Rescan". When I did this, my X4850 miraculously connected and started working.
Rick from Austin
SOURCE: laptop lost wireless connection to printer
Is is a wifi connection? What type of connection do you use? Adhoc or infrastructure(meaning does it pass through the wifi router or direct to the laptop)?You may have to reconfigure your wifi.
SOURCE: wireless
I had the same problem. It is now working.
The problem was a bad conecction of the network interface card.
I simply pluged it out and inserted it in and it is now working fine !!
Hope it works for you.
SOURCE: Lexmar 4875 Flatbed Wireless printer not connecting to the networ
I know you posted this in May, so have probably given up and bought a new printer by now, but I thought it worth mentioning that I had the same problem exactly (though without the same number of iphones and laptops!).
Buried away in some documentation on the driver CD, is the fact that the X4875 can't communicate with a secure wireless network that uses a TKIP algorithm - it can only handle AES. My router used TKIP out of the box, and I never thought to change is, especially as it's stronger than AES. However, changing it to AES solved the problem.
By the way, if you're using Vista, you may find that you have to run the install package in Windows XP compatibility mode, and then when the install is complete, manually change every .exe under c:\program files\lexmark\.. to run in XP compatibilty mode too. Works for me (Vista Business), but didn't work wirelessly at all before. Good luck,
Chris J.
SOURCE: User's Guide does not contain software installation instructions.
I would recommend you to reinstall the driver from the below link. also if you click on Technical support - How to install downloaded driver it will show you how to install it.
-http://www1.lexmark.com/products/view/All-in-Ones/Lexmark-X6570/catId=cat10004-category&prodId=4165-product;jsessionid=36351499255753845B8F3686DDD5E41C.node3
Also in the related links there's user guide for the Printer. it has instruction on how to configure network on your printer.
Please let me know if you have any further questions or concerns.
Thanks.
