My D2X is behaving very strangely... it had been working perfectly up until this morning; when I tried to use it I could only take 15 images before it refused to take any more. I thought that it was maybe a memory card issue and switched the camera off although I couldn't actually get it to power down until I removed the battery. On reviewing the images it told me that the 'File does not contain image data'. More in hope than anything else I then tried an alternative battery and lens and I noticed that until I actually took an image I could power off and on the camera but then it would only let me take the 15 images again, and wouldn't power off again. Also, when I tried to read the memory card to see what had been recorded it was blank.
SOURCE: Screen
Get on to Nikon and let them know about it, it is a common problem with the S4. They are fixing the 3500 and others for free. John.
SOURCE: FOLDER CONTAINS NO IMAGES.
Please follow the instruction below and let me know what is happening.
1. format the new card.( Can't format is from any virus
infected PC ).
2. Insert the card then reset your camera setting.
3. select your mamory card default for save the
photographs.
4. Before start photography confirm that your battery
is fully charged.
Thnaks & please give me feedback about your camera.
SOURCE: "File contains no image data"
Try a new SD card. SD cards do fail.
The socket inside the camera maybe no good - bad connections.
The camera may have liquid damage - this causes all kinds of weird issues.
I try the cards in my computer reader. If they can be used all day there (I load and unload stuff randomly all day to test and then put the card in a drawer for a few days and check what I loaded later), the fault is likely the camera.
SOURCE: "FILE CONTAINS NO IMAGE DATA"
It may be of your new SD card. Try with another SD card. It may not show you File contains No Image Data. -Lalith
SOURCE: my camera says memory contains no images, I have a
You may refer to this camera photo recovery guide that helped me before
Recover images from digital Camera
