Need to replace the receptacle contacts on my electric cooktop.
Cartridge terminals have carbon on them.
Parts Store indicated that the receptacle contacts may need to be replaced. I have already replaced the infinite switch, however the element is not heating. Any help you could provide would be greatly appreciated.
Thanks
SOURCE: on light flashes
i would replace the custom control kit. elemnt usually fine that contorol kit is a new circuit board that only controls that one burner
SOURCE: jenn air jed 8430 electric cooktop control switch for rear burner
The cook top is attached to the wood frame by brackets, just remove the screws and the electric connection, make sure the power is off from the main box, it's a 220 volt wiring and then just lift the top off. to remove the glass, look around the edges and you should see some small screws, just remove them and the glass should lift off.
Eddie Rentas
Tupper Lake NY
SOURCE: JENN AIR GLASS TOP REPLACEMENT
the glass top replacemnt is a pretty straightfoward task, a matter of unscrewing one and repalcing it wiht anew one. after ordering new top its a matter of lookin g at eh new top to see which screws would need to be removed from old. hardest part about job will be youll need to do disconnect the downdraft from the venting ,and pull unit up from the counter inwhich it is installe.< not difficult but cumbersome and awkward to manuver. check abd verify full model and serail number and cal manufacture for correct part umber. may cast anywhere fom 200-400 dollars depending on model
SOURCE: I cracked the glass on
Try your local dealer. The tops can be expensive. I have seen them start at around $300.00. Check your warranty and maybe you can get it done under that. They would put like 5 years on those tops. May have to tell them that it broke when you where cooking, blame the product, not you.
SOURCE: I need instructions for wiring in replacing a dual burner switch
We followed the instructions that came with the switch that addressed a "compound wiring" configuration. We also used the black jumper wire as shown in the instructions.
We got to this solution in a trial by error manner though, because the three of us working the problem were convinced the stovetop was wired in a "piggyback configuration" and tried that road first. It would have been helpful if the instructions had included an explanation of the switch manufacturer's interpretation of "compound" and "piggyback" configuration.
In order to test the surface burner on your electric range, the following steps should be taken:
An oven thermostat is a switch that opens and closes in response to the temperature
it senses. It is typically found in the control panel, where a
liquid-filled temperature-sensing bulb senses and maintains the internal
oven temperature by cycling heat on and off.
Adjusting the thermostat:
Hi phassit, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What model number
