As I said above, it was working perfectly well 2 weeks ago. Not in use on a daily basis. Loaded it last Friday and it would not work: the ON button/light is not working, nor are any of the 3 programmes.
SOURCE: No power for my Siemans SL84A dishwasher
Not a solution but a cause for my DW having the same problem. One of the four wires going to the On/Off switch shorted and burned. I never lost power to the unit, as far as I know there is no reset button of fuse. I rewired the unit and ran several washes without overheating or shorting.
SOURCE: Siemans SE64A630GB Integrated Dishwasher - seems
Hello....My name is Keith.....Please give me one minute and I will start to address the issue. Thank You....
SOURCE: I have had an
Hi Steve E24 error normally indicates failure to drain, the first
thing to check is that the water is actually being supplied to the appliance
and is turned on. If it is then check the water inlet valve, if the valve tests
fines then clean the drain pump assembly completely as that might be clogged
causing this issue. Hope this helps...please post back for further assistance. Daniel
Hi
It may be an
issue with heater circuit, door switch or wash pump, please reset the power to
the dishwasher. After, 5 minutes check if you are still getting the same error.
If yes, then it is a water heating fault. To resolve this error try pressing
this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air
Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub,
energy saver dry. Now let the unit run for 2-3 minutes and then you press
the Cancel/Drain button and allow it to completely drain and reset. If this
doesn't work then it's an issue with the wash pump not pumping the water past
the heater efficiently or due to lack of water to heat. Please make sure that
heater is not open circuited and is heating the water efficiently. You'll have
to check the heater using a multimeter; the meter should read between 3000 to
3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure
water pressure is optimum and fill valve is working fine. Hope this helps...
Please post back if you need more information.
Daniel
