Do you mean while you are already on the phone? Like if you are calling somewhere already & they say "for customer service, please press 1?". If so, you can press & hold unlock button while you are on the phone, then 3 choices come up on the bottom of the screen. One is dialpad, just press & hold that & dial pad will come up & you can then press a number.
Hi Nilesh, the user's manual says, quote: "Speed dial: If you already set the speed dial numbers, then you can long press number key 2 to 9 to dial set numbers out under the standby mode.Long pressing number key 1 is to dial to voice mailbox if you already set the mailbox number." So it looks like you need to add the speed dial option in your chosen contacts details, first. Then follow the quote above. Good luck!
To change the contact that is assigned to a speed dial key, click Edit. Click a new contact.
To assign the contact to a different speed dial key, click Move. Roll the trackball to move the contact to the new speed dial key. Click the trackball.
To delete the contact from the speed dial list, click Delete.
Decided to try running a magnet over the phone front & back horizontally and vertically, like I had read other people did to fix other freezing problems. IT WORKED!!! :D
MOT OF THE SEVICES REQUIRED FOR BROADBAND DIAL UP NETWORKING ARE ALREADY GIVEN IN THE WINDOWS AND THE REST CAN BE ADDED BY USING YOUR WINDOWS XP INSTALLATION DISC
basically the way i do it is, press the dial button with the numbers, then press down and number which doesnt have a speed dial already, and if you hold down it will say " no speed dial set " and then it will take you into the next bit :P
To assign a number to a speed dialing key, select Menu > Address Book > Speed dial list, and scroll to the speed-dialing number that you want. Select Assign or, if a number has already been assigned to the key, select Options > Change. Select Find and the contact you want to assign. If the Speed dialing function is off, the phone asks whether you want to activate it
FOR MAKING CALL
Assign a phone number to one of the speed dialing keys, 2 to 9. Call the number in either of the following ways: • Press a speed dialing key, then the call key. • If Speed dialing is set to On, press and hold a speed-dialing key until the cal
