SOURCE: DynaPoint hc3003 optical wheel mouse driver
You will need to login to this website to get the drivers. User: drivers Password: all http://members.driverguide.com/driver/detail.php?driverid=650073 Hope this helps. Ray
SOURCE: USB optical wheel mouse not detected by XP
Hi, You can try to: Right click on "My Computer", click on Properties, click on the Hardware tab, click on the Device Manager Button, expand your Mice and other pointing devices. verify that you 2 entries. One is the Sony builtin (Alps in my Vaio) and a HID-compliant mouse. The latter is your external optical wheel mouse. Make sure it does not have any red or yellow mark. Double click on the HID and verify that the next window says "This device is working properly." If not follow on screen instructions to enable or activate. Hope this be of some help. Good luck and pls post again how things turn up or if you need further information. Kind regards.
SOURCE: optical usb mouse cursor frozen
If it is a USB wireless then your operating system will not need any additional drivers. The USB port takes care of that. Windows XP and Vista support almost 100% of any USB wireless mouse including Logitech..I own three of them, never had a problem. The only problem would be the USB port itself. Which is a totally different subject. You can still also go into control panel and make mouse adjustments if needed.
Please rate solution.
SOURCE: IBM Optical Scroll Mouse doesn't work (Device Driver Problem)
connect your mouse. then restart your laptop do not remove mouse while restarting laptop. if not work after restart there is a problem in your mouse IC.
