Epic A35T Treadmill Logo
A
Anonymous Posted on Apr 07, 2013
Treadmill stuck in initializing update - Epic A35T Treadmill
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1988
Points
Here's what I had to do to resolve this...Click on the radio icon that's in the lower right corner of the screen (the wifi icon)...that opens a wifi configuration screen (even when it says initializing update!)...then TURN ON wifi (it was off for me) and connect to my wireless access point...once I did that, the process moved on from initializing update and proceeded to the asset recognition screen--and downloaded more stuff. This process finished and I was able to use the system again!
  • Anonymous Apr 10, 2013
Treadmill screen won't stop counting/running unless i unplug it. This was after a firmware update.
If you wish to get some details about treadmill repair and service ; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Precor 9.23 Treadmill Inclines Randomly
most prob one of sensor / connection gone bad
Incline stuck treadmill
Run the software calibration for easy diagnostic and fix it. Lube the incline mechanism. Go to Hood cover motor and follow the steps or read your owner manual.
God bless you
My treadmill is stuck in incline
please RUN the software calibration for easy diagnose, troubleshooting, and fix it.
see the diagram attached, for troubleshooting too.see the b.diagram
Happy New Year.God bless you
Nordictrack c1750 firmware stuck in checking for updates?
Reset the machine, see the button in the instr. manual and proceed according.
God bless you
Lower incline
Dear Sir:
I STRONG recommend RUN the calibration Software Inmediately, for eay Diagnose and troubleshooting, most of them instruction has coming in the Hood of Motor, follow the instruction or use your instruction manual.
Adjust the sensor speed attached the diagram. Tight the wires from sensor speed. The sensor speed can be faulty. Adjust the Pot with the gear in the same motor, both can be faulty. And finally the main motor board can be wrong. sincerely.
God bless you.
ernesto cuadra
managua, nicaragua.
3helpful
T3 Treadmill Stuck Key
The cause of a “STUCK KEY” error message on the Basic or Advanced consoles. A stuck key error is displayed when one or more keys on the console or activity zone remain actuated for more than 45 seconds.
SOLUTION
Recycle the power. If the key remains stuck, the console will display “PLEASE WAIT” until the stuck key error is displayed again. Determine the stuck key. Replace the console if the problem is a key on the console. Replace the activity zone membrane keypad or the activity zone circuit board depending on the product if the problem is not in the console.
2answers
RCA Mp3 Opal 4202 is stuck on Initializing. How do I
What i would recommend is for you to reset the device, after you reset the device if you are still having the same problem try to update the firmware...I hope that helps..
2answers
Why did my rca opal mp3 player went into initializing
Initializing is normal - getting stuck on initializing for more than 5-10 minutes [this is after you have downloaded your first batch of 1 million songs (I'm using hyperbole)] is not normal. reset he player, try again. If it fails still go to RCA's support site, or repost new problem here.
Top Epic Exercise & Fitness Experts
ADMIN Andrew
ADMIN Andrew
Sportsmith LLC
Sportsmith LLC
Don A
Don A
Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
