Solution anad repair
Steps to troubleshoot Canon Printer Error P07:
Method 1: Try following the method
In case the Canon Printer device is not functioning properly or to clear the memory user needs to reset it.
On the operator panel, press the button. Make sure the user has unplugged the power cord if pressing the ON button does not shut off the Canon printer. Canon Printer Error Code P07
The user needs to wait near about ten seconds and then press the button again.
User now need to wait until the device has completed its cycling process before submitting another job request. Make sure user now also unplug the power cord and retry if the above steps do not clear the error.
->Turned off printer
->Press STOP / RESET and hold, then press and hold the POWER button.
->While POWER button is pressed, release the STOP / RESET, then press the STOP / RESET 2 times in a state of the power button is pressed.
->Release both buttons simultaneously.
->The computer will detect a NEW DEVICE, Ignore it .....
->This situation indicates the printer which Error P07 is in a state SERVICE MODE and ready to reset with software.
**If you need any technical help on printer then you can reach at http://www.vtechsquad.com/printer-support/
