Dimplex DS5598 Mid-Size Heater Logo
Posted on Mar 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dimplex storage heaters dead
I was on holiday left heaters on low when i came back they were all dead tried white button inside heater didnt work liz
anantha reddy
Level 2:
Sergeant:
Champion:
  • Expert 205 Answers
  • Posted on Aug 06, 2009
anantha reddy
Expert
Level 2:
Sergeant:
Champion:
Answers
205
Questions
0
Helped
75450
Points
554
Sir please check the heater connection inside.then check if there are any damages in the control cables.
Hi, I have a Dimplex DUO500i storage heater and
Sounds like you heating coils burnt threw. how much did you pay for it? Might want to buy another.
Dimplex duo storage heater making clicking noise and also the programmer dimplex PX4 is no longer working
Iv sorted the problem. Iv had 3 dimplex heaters fitted and the one in the living room was making a shocking and most annoying clicking noice when the fan stopped and started... it was annoying to hell.... At the bottom of the heater left hand side I loosened (just two turns) of screw in the grill. My heater has been perfectly silence every since. The screw was far to tight.
Water heater timer not working or bad wiring?
10/15/2012
Hi Liz.
This is a live answer. And you can add a comment after trying following step, and I will comment back..
Replace battery, and then reset the timer using reset button located to left of display screen.
http://waterheatertimer.org/pdf/eh40-english.pdf
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
1helpful
I have economy 7 dimplex storage heaters and last winter they just decided to stay stone cold and not come on one day. can these be repaired or do i need to replace the whole heater? thanks
I belive inside the front cover this a bimetal reset in one of the corners top right I think you have to push this back on it makes aloud click . do this with the power off , have done this but a long time ago . hope this helps
I have a Dimplex Ritz electric 2000w heater that is only working on the low 1000w setting. When the high setting is selected it auto turns off and there was a funny smell which I am assuming a fuse has...
Yes, it can be repaired, if Dimplex still stocks that particular heating element. It's not to difficult to replace the heating element, just mark all the wires before removing the old one. Also, it will require removing the logs inside the heater, because you will need to turn the stove upside to do the removal and replacement. Contact Dimplex Technical Support at 1-888-346-7539.
Hope this helps you.
Hi - I have an old Glen Dimplex CLX (I think is the name) wall heater. The switch for turning on the heater broke 2 days ago. It sounded like a fuse blew. How on earth can I get this fixed?!
You say the heater is 'old', so I assume that it's out of its 2 year warranty? Are you referring to the wall-switch or the switch on the heater itself?
The customer service department will be able to give you guidance on finding the problem and resolving it. If you call 0845 600 5111 and have your series number (top left of the unit) and model (CXL) to hand they will be able to help you.
P.S. Please don't try to take the heater apart or remove it from the wall unless you have experience in working on storage heaters, as the unit is VERY heavy!
2helpful
Dimplex oil heater FR24. 2400W oil heater. shorts fuse box
I would suggest that the element may have absorbed some mloisture whilst being left in storage for a period of time. You may need to take it to a local repairer to see if they can dry out the element.
If there is moisture in the element it is not safe to use, hence it trips your circuit breaker.
2helpful
I have two dimplex XLN storage heater, it was working last year but after someone put damp clothes on it, they are not working, could you help me please
It sounds as though it has tripped the internal cut-out - this can be manually reset quite easily by yourself. It would probably be best to ring Dimplex customer services on 0845 6005111 to get them to talk you through it step-by-step though.
7helpful
My dimplex night storage heater has stopped working.
...not too sure of your model but all dimplex heaters to my knowledge have an 'overload' cut out built into the system. Ours is more up to date but still goes now and then, problem is you have to get into the electrics and click the reset button, normally near or on the thermostat it's self, could be a small white plastic button, or a piece metal sticking up that needs pressing down to reset...but please before attempting make sure that you TURN OFF THE ELECTRIC / REMOVE THE FUSE/ WHAT EVER IT TAKES TO CUT ANY CHANCE OF AN ELECTRIC SHOCK!!!...because I can and will get you if it can ;-)... if your not a competent electrician please get hold of one !... good luck.
1helpful
Early / Late boost in dimplex storage heater
The output setting if turned off isn't adjusting the temperature in the room automatically if its off,and by turning the output up is like turning up the heat.By turning the output switch on you can let the heater automatically control the heat.Still you need to monitor the adjustments to your liking and then you know how hot it will be when you come back into that room.
Top Dimplex Heating & Cooling Experts
Paul Carew
Mike Cairns
Mike Cairns
ADMIN Andrew
ADMIN Andrew
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
