SOURCE: 140hp johnson seahorse tilt will raise the motor
it needs fluid added. had a 70 johnson do the same, I saw no leaks but it was low on fluid, put some in and have had noproblems yet.
SOURCE: 1978 johnson 25 hp
Hi, make sure you are using a genuine pin and if so check the back of the prop where the pin sits for wear, regards Phil.
Suggest you get that done well before taking it off the boat trailer! Barring that, get some good twine at your local hardware store and use that with the cowl off.
