Hi and welcome to FixYa. I am Kelly
If your are sure the dryer is heating then there are a few things you muct check.
1. First of all remove the lint filter.
a. Inspect all of the air passages around the lint filter for lint build up.
CLEAN with a vacuum and crevice tool
b. Wash the lint filter with vinegar and water then soap and water. If you have been using dryer sheets in the dryer the material fromthe fabric softener sheets cakes onto the filter. The filter appears clean but will not allow good air flow through the dryer.
c. Remove the vent ducting from the back of the dryer. Clean out all of the ducting inside the dryer that you can reach. If you have to use a folded wire coat hanger to remove the lint in the dryer along witht he crevice tool.
d. Continue to clean the exit ducting on the house side of the ducting all the way to the wall exit. Go outside inspect and clean the vent flapper on the outside of the house.
e. After doing all of steps a - d above. While the vent is disconnected from the dryer start the dryer and check for a strong HOT air flow from the dryer vent exit hole. If there is not a strong HOT air flow there is still a problem with lint build up or the blower fan impeller is loose / broken on the motor output shaft.
Everything listed above assumes that the dryer is still heating. If the dryer is not heating then respond here and we can go from there.
Diagrams of your dryer can be found here:
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=110.63032102+&=part+number&pathTaken=partSearch
Thanks for using FixYa.
Kelly
