Check the filtering on your router
add the ip address of your printer into mac address of your router
add the ip address of your printer as well to your firewall
According to Lexmark the new drivers that are on thier web sit will allow you to use WIFI.
Here is the link
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Don
Ull the power plug out for a few seconds and then IN, now press the START on the printer and it will connect again. happens to me quite often. flyhal
For more detailed instructions on how to use your printer, please refer to the Lexmark X6650 User's Guide.
Print the network
settings page to identify if your printer is connected to your wireless
network:
1. Press Setup on
the printer operator panel.
2. Press the right or left arrow button until Network
Setup is displayed, press OK.
3. Press OK at Print Setup Page.
4. Press OK when prompted to Load Paper.
5. Press OK. The network settings page will now
print.
Check the Network Card Status, SSID, Trouble Code, TCP/IP Address.
SSID should be the name of your wireless network. Otherwise, you may need to
reset the printer's wireless network settings.
How to
reset network settings:
1. Press Setup.
3. Press the right or left
arrow button until Reset Network Adapter Defaults is
4. Press the right or left arrow button to display Yes,
pressOK.
Once the Wi-Fi light turns on to solid orange, run the Lexmark
Wireless Setup Assistant on your Mac.
I need to knw the operating system, Win XP or Vista? Don
Question, have you by chance moved the printer and blocked the antenna?
