HP LaserJet CM1015 MFP All-In-One Printer Logo
A
Anonymous Posted on Apr 05, 2013
PCL XL error Insufficient-memory operator rectanglepath
1 Related Answer
syed mahmood
  • 77 Answers
  • Posted on Dec 16, 2009
SOURCE: PCL XL ERROR
re load the software and check the buffer system
Pcl xl error error: insufficient memory operator: rectanglepth position : 751 How do i correct this problem
Solution
The possible reasons for this error message are as follows:
  • The document is containing both image and text.
  • The font is not supported.
  • Embedded fonts are used.
  • A special plug-in is used.
This issue can be fixed by enabling the following option in Printer Preferences .
To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet CM2320 MFP Series PCL 6 , and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Rameshkumar . R
[email protected]
PCL XL error Error: InsufficientMemory Operator: EndPage Position: 152856
Add more memory into your PCL printer -- each printed page is produced by your printer processing the PCL (Printer Command Language) commands. The page that you are trying to print is "too-complicated" for the printer to generate, giving the limited amount of RAM currently installed in the printer.
Or, reduce the complexity of the page that you're trying to print.
PCL XL error problem
Try to update the latest firmware for your printer.
PCL XL error when i give command to the printer from my pc, i get the following error PCL XL error Subsystem: KERNEL Error: IllegalTag Operator: Oxlb Postion: 6
I already answered this, but the response did not get posted.
The short answer is that the PCL XL interpreter has picked up the use of the "Escape Code" (0x1B) in the incoming datastream. This command is used for the standard versions of PCL, most notable PCL 5e. It is not used in the PCL XL datastream.
Don
1helpful
I have an HP Color LaserJet 3800 printer. I am trying to print a document and it keeps printing: PCL XL error Subsystem: GEDI Error: MemA L LocError Operator: ReadImage Position: 743
That means that the printer does not have sufficient memory tp [rint the document, if it is a text document (eg word) try to print pages in groups, if it is a different document try the following:
" I receive a 'PCL XL error' on my HP 4100mfp when making a 2 page copy as one page in duplex? Why?
The problem is related to a printer memory problem.
If following parameters are set in the HP 4100mfp you will receive and 'Insufficient Memory" error.
1) In 'COPYING' the 'IMAGE QUALITY' is set to 'BEST'
2) In 'ORIGINALS' the 'CONTENT' is set to 'PHOTO'
Following error message is printed:
PCL XL error
Subsystem: GEDI
Operator: EndSession
Position: 32
The solution is to set 'CONTENT' to 'MIXED' or 'TEXT' or set 'IMAGE QUALITY' to 'NORMAL' or you can add additional memory to the HP 4100mfp. "
from euroform.com - FAQ
2answers
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
3helpful
PCL XL ERROR INSUFFICIENT MEMORY
you can try to use the HP 5L driver instead of the canon driver, I suspect you get this error when printing PDF files
k24674
Grand Canyon Tech
Grand Canyon Tech
