When i start my laptop then tha laptop automatically shutdown after 3/4 miniates
SOURCE: Hi i have msi u230
try to make a bios update but it was not advisable since it causes more problems. another one is to toggle the "Legacy USB Support" in bios if it was enabled try to disable it and vice versa. then boot your OS and check if the cam is working.
SOURCE: where can i locate CMOS
I also open one of the MSI wind U100 series netbook when you removed the keyboard try to locate the black and red wire in the lower left corner of the board and trace it.
SOURCE: notebook msi u230 says plugged in not charging and
Turn off your laptop first, then remove the battery. Plug the charger then turn on your laptop wait until it loads completely then put back the battery on your laptop while it's on.
I hope it will work for you.
SOURCE: MSI U230 microphone is not working
Check you Audio Sound properties and make sure the microphone is checked as a Recording Device. Click Start/Control Panel and look for Audio or Sound. You might also be able to click the megaphone that is located at the bottom right near the time.
You can talk till you are blue in the face, but if the Microphone is not selected as a recording device it won't work.
Some operating systems will allow you to do a self test of the microphone by clicking Start/Programs/Accessories/Entertainment/Sound Recorder
SOURCE: my MSI U230 micophone in not working
Some
