Archos 80 G9 Turbo 16GB 8" Multitouch Screen Android Tablet Logo
Sue Jagger Posted on Apr 05, 2013
My archos 80 g9 froze the day after i bought it and it wont unfreeze
worldhound
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Apr 05, 2013
worldhound
Contributor
Level 1:
New Friend:
Answers
12
Questions
Helped
1961
Points
25
1) Take it back to where you bought it
2) Unplug all the cables, including the power cord
3) Press the power button and hold it for 30 secs (or so)
4) Replace the power plug, try to turn on the monitor
5) If it turns on, turn it off again
6) Now attach only one cable, then turn it on
Did that clear it? If not, issue is with video card and monitor combo
2helpful
How to change the battery in an archos 80 g9
very small scew under kick stand two more under feed opposet of kickstand screw driver catch latch left and right sides of achos logo pop open plug and play hope that helps :)
ooooh one more thing beware the only thing holding the usb port in is the screen it may slide out of place when you open the tablet its not supposed to be opened and is a little tricky to line up when your closing it again.
finaly only do this if the warntee is up archos will replace the internal batter for free if it is still under warantee
finaly the archos 101 battery also fits the 80g9 but very snugg it will however give you just shy of 48 hours constant use over the 15 hours that the 80g9 original battery will i had mine playing a 80 hours youtube play list for two days before it lost power and did not plug it in just to see how long it lasted roughly 53 hours i think
3helpful
Where is the serial number on Archos 80 g9
Under the kickstand,The Serial Number is the PC114x one.
Where to buy lcd screen for archos 80 g9
not sure you want to do that you can google it, it does come up with places that sell it. problem is they dont always work you may have to buy 2 they will charge you to fix it if it is out of warantee aprox 25% of the value of the device or just shiping if still under warantee but LCD/LED is not coverd by warantee if you can convince them that the display malfunction is something other than the LCD/LED they will replace a waranteed one for shipping charges alone no questions asked but you have to convince them it is some thing other than the phisical display its self wich should not be too dificult they are pretty durable and can still display a fairly good image even when cracked in multiple places often the touch screen will also still work when cracked too not very many tablets can say that :) hope that helps
1helpful
Hi, my Archos 80 g9 display screen is broken, can i buy new display from you?
the display screens can be purchased but good luck finding some one to install it just google it and buy 2 because often some of them dont work from the factory ooorrr you can have archos fix it wich may be cheaper and easyer about 25% of original cost and they will test it and make sure it works before sending it back or send you a new one the screen problem is not specific to archos its specific to that type of screen they have a half life of about 5 years but may die sooner under constant use or abuse and some die as soon as they are powered having archos replace it prevents you from having to buy multiple of them to find a good one samsung also uses the same type of screen but does not use the laminating or layering proces that archos uses to increase the durability and third party screens also dont have this eather so having archos do it will also ensure you get a laminated and layered set up that will last you a bit longer than one you might purchase after market and have some one put in for you
2helpful
My tablet as frozen i am unable toswitch it off
Hold down your power button for 15 seconds.
7helpful
My archos froze and i cant unfreeze it
I am glad to HELP YOU!
To UNFREEZE your device you have to do like this:
# press and hold DOWN your POWER button for 10 seconds
# once the device is POWERED OFF recharge the battery COMPLETELY
# when battery is FULL restart your Archos 101.
And make sure your firmware is UPDATED!
Now your device should work properly!
GOOD LUCK!
... and don't forget to RATE, please...
useful WINDOWS TIPS!
I was on the internet on my archos 5 and it froze
Mine gets into a funky state some times. Try to do a cold power reset. remove the battery, wait 10 secs, put it back in, put power into from the USB cable then try to power it up.
Top Archos Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
